sell top speed arm. buy 300degree camber kit along with some nismo bushings for the stock arms. problem solved. i had the z1 arms and i could never keep them tight, and most of the midori arms were were designed for the skyline. they will end up bent or will loosen on you after a few miles and bad roads. having to constantly check them is not worth it to me. good luck though.
